Please post a pic of a modified Centerbolt.!!!!
Old Feb 19, 2001 | 10:33 PM
vortech305's Avatar
Evey time i get a smart remark from a guy who says just grind here and there and shows me a pic of a chain saw. Lets be relistic Please post a pic of the INSIDE of your modified(etc.grinding,sharpening)centerbolt valve cover, I have roller rockers and i was told to grind some parts off and i just want to see how modified valve covers look like from the INSIDE. thanks. If i see Just one pic of a modified valve cover ill never bother u guys again.
92' camaro
New 305 block TPI conversion, Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads accel cam,52mm throttle bodie, SLP runners,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods msd 8.5 mm wires hypertech coil and plug, Edelbrock TES headers, free flowing catalytic converter and a 3 ich force II flowmaster exhaust system.
Soon to come!!!
Procharger system 12lbs o boost.
Favorite quote: "where ever u go, there u are"
Old Feb 20, 2001 | 11:06 PM
vortech305's Avatar
comon guys one of u's got to have a pic
92' camaro
Soon to come!!!
Old Feb 21, 2001 | 06:11 PM
ede's Avatar
ede
sorry no pics, but i just added a few inches to a set for my little engine. i took one set and clamped a piece of 1x1 angle on the lip of the gasket flange and used it as a guide for my cutting disk. i cut the "tops" out of 2 valve covers this way. then a took another 2 valve covers and turned then bottom side up and ground the seam where the top meets the gasket flange. if you look you can see how it's formed out of one piece of steel. doesn't take much grinding before you get a blue line where the metal seperates. with a little help from a hammer you can lift the entire valve cover off the gasket flange. i then took this piece and welded it to the flange with the 1" stub of valve cover. i matched them up and used a grinder to level out the high spot for a closer fit. the metal is about .030 think so it doesn't take much to burn through. i used a small gas torch on one and mig on another. guess if i do any more i'd try tig on it. i like my method way better than trying to splice in a piece of steel. i think it was harder trying to tell how i did it than doing it. good luck
ICON Motorsports
1st & 3rd
Old Feb 21, 2001 | 09:38 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I had no interference with the stock centerbolts and 1.6 rollers. The only thing I had to do was take a pair of vise-grips and crush the oil baffle a little.
87iroctheo
Dec 4, 2016 11:47 AM
aaron7
Aug 17, 2016 06:02 PM
pimprs
Aug 24, 2015 11:20 PM
BurlyChev
Aug 22, 2015 01:52 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
