Help!! My Cam has been broke down for 3 weeks
Old Feb 19, 2001 | 05:10 AM
boo36's Avatar
I need some help here...About three weeks ago I took my car in to get detailed. Its a 89 Camaro, EFI, 305,TBI. It was running as good as ever, I picked it up from and about a mile from the detailers shop it won't idle. I took it into a "preformance shop" and the guy says it needs a tune up (no test ran). $240.00 later and 3 more days, he tells me its fixed. No such luck, same thing. I then took it to GM dealer to get test ran, EGR faliure (I replaced that). The same day I replaced the EGR, I start getting "Service Engine Soon" Light. I drove the car for the rest of the day. The next day I get in it and the motor will not turn over but all the gauages work. I have several guys try to look at it, I buy a $23.00 code reader. the codes that come up are: MAT Sensor. (this checks out fine) manifol air temp; BARO baromatric pressure sensor circuit faliure; and the third code; System volt too high(over 17.7 volt to ECM) or EGR system fault or alternator voltage not normal or Vehicle Anti-Theft Saystem Fault. We have tested all the sensors and relays. I have been told that the ECM might have gone into limp mode? Could it be the fuel pump relay, or the fuel pump its self? Someone help please, I am running out of money? Could this datailer ruined the ecm?
www.kimbaluubug@aol.com
[This message has been edited by boo36 (edited February 19, 2001).]
Old Feb 19, 2001 | 11:37 AM
84TransAm's Avatar
Even though i don't know much about the ECM, it sounds like it has been ruined. Won't be a cheap part either.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Old Feb 19, 2001 | 11:45 AM
The ODB's Avatar
don't know, but sometimes the ECM itself fails and has to be replaced.
perhaps someone at the detail shop borrowed yours, or swapped for one of your good sensors.
I know a guy that test drove a new camaro just to swap his bad MAF for a new one for free.
Old Feb 19, 2001 | 10:18 PM
Vader's Avatar
Boo,
Reinitialize the ECM. Drive it for about half an hour, then scan for error codes again.
Waiting for your report back with results.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 19, 2001 | 10:25 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Did the detailer also clean the engine bay? If so, I'll bet a donut that the TPS got wet and is now toast.
"Only in Britain could it be thought a defect to be “too clever by half.” The probability is that too many people are too stupid by three-quarters."
John Major
Old Feb 19, 2001 | 10:35 PM
82RECAROTA's Avatar
Old Feb 21, 2001 | 11:00 PM
boo36's Avatar
Dude Vader: This sucks SOOOOO BAAAD....I had my rod towed home today. Tomorrow morning I will " reinitialize" the ECM. This is how I understand how to preform this mission. Disconnect the both battery cables for 5 minutes reconnect (and with, ALL fingers and toes crossed) the dark grey ghoast will start?
<font face="Verdana, Arial" size="2">Originally posted by Vader:
Boo,
</font>
Old Feb 21, 2001 | 11:33 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I'm not Vader, but you don't have to disconnect both cables, just the negative (I say negative, because it is the first that should be removed anytime!)
By not turning over, do you mean that it won't even crank, or that it will crank, but not start?
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand.
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Feb 22, 2001 | 12:05 AM
boo36's Avatar
JP...Sorry I just pushing buttons and POUNDING on keys tonight...It will not "Crank" but the dash, radio, gaguages (sp?) come on. the motor makes no sounds, and I do not hear the fuel pump come on????(
<font face="Verdana, Arial" size="2">Originally posted by JP84Z430HP:
</font>
Old Feb 22, 2001 | 12:33 AM
yellowiroc's Avatar
check your fuel pump pressure. The reason you don't hear it prime is because it hasn't relieved pressure by being started. I doubt something got ruined by water because if it was water, you wouldn't have left the parking lot. I used to work in a detail shop... chances are you got something swapped. That's why you learn to do these things yourself because in the world today you can't trust anyone.
86 IROC 305 TPI LB9 700R4 W/ Shift kit, K & N, Flowmaster gutted cat 95 Z tips, airfoil, 160 thermo, removed emissions, Summit cam kit 442 lift springs and lifters, ADS super chip, Summit timing chain, modified MAFS, tranny cooler, polished rims, Good Year yellow letter nascar 235/55 tires, polished runners and plenum, 145 Speedo, remote start, keyless entry, alarm, yellow neons underneath.
Fronzizzle
Mar 18, 2019 08:29 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 26, 2015 04:59 PM
michealleger
Aug 26, 2015 03:29 PM
