Question about oil filler cap
Old Feb 22, 2001 | 06:31 AM
Steve's Avatar
Car: 91 Z28
I have a 91 Z28 L98. Where the oil filler cap is on the valve cover, there always appears to be oil residue there even after i clean it. What i have noticed is that cap does not seam to seal air tight, so i think oil is getting past it. what i want to know is this normal or should i go out and buy a new cap?
Thanks,
Steve
Old Feb 22, 2001 | 06:45 AM
Mike89GTA's Avatar
My guess is that it is not normal, but the cause is probably a bad PCV valve. I would replace that first.
[This message has been edited by Mike89GTA (edited February 22, 2001).]
Old Feb 22, 2001 | 08:43 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are supposed to seal, but very often they leak after the Belleville washer that's supposed to keep them tight loses its "dome" attribute. As cheap as they are, like 4 bucks or something, if you don't like the leak, just get a new one.
ICON Motorsports
Old Feb 22, 2001 | 09:13 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Your cap is the screw in type with the anti-over-tighten feature like a gas cap right? It's too cold out for me to look but isn't there a rubber washer under there? Red or pink I think?
Shake the PCV. I don't think oil would make it through the threads even if there was no washer. I could run mine with it off and never get a drop to fly outta there. Some source of crankcase pressure pushing 'oil mist' through there IMO.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
