Pinging - 89 RS TBI
Old Feb 22, 2001 | 08:39 AM
Alan84TA's Avatar
Pinging - 89 RS TBI
My friend has an '89 RS TBI that pings really bad when the engine is under load, like going up a long hill. Also at times it will make a noise like a ping but really fast almost a grinding noise and puff a little smoke... whats causing this? Timing?
Old Feb 22, 2001 | 09:37 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
either hes using bad gas (below 89) or his timing is advanced past 0*BTDC.
Old Feb 22, 2001 | 10:26 PM
Blue89RS's Avatar
Run some combustion chamber cleaner through it, Gumout makes some good stuff for it. Then run a few tanks of 91 octane. he might have had some bad gas...
Old Feb 23, 2001 | 01:33 AM
Dan87IROC-Z's Avatar
It may be bad timing, bad (not just low octane) fuel, or maybe a restriction on the exhaust, like a clogged catalytic converter.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 23, 2001 | 05:16 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes, the timing should be checked 1st, thats what it usually is, but not always.
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
[This message has been edited by IROCZTWENTYGR8 (edited February 23, 2001).]
Old Feb 23, 2001 | 07:46 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Timing, bad gas......when was the last time you gave it a tune up??
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Feb 23, 2001 | 08:09 AM
FastBroker's Avatar
Or a bad head gasket.
Old Feb 23, 2001 | 09:41 AM
Alan84TA's Avatar
I'll check the timing first. It has a new exhaust system with no cat so I don't think thats it. If the timing is ok I'll run some cleaner and some high octane fule and see what happens.
Old Feb 23, 2001 | 01:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Isn't there something also about carbon buildup inside the EGR valve can cause pinging at low rpm/high speed engine operation? Or am I just thinking of port-fuel-injection?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Gordonr1973
Sep 29, 2015 11:59 AM
