Cam bearing...did i skrew it up?????
Old Mar 22, 2004 | 11:58 AM
Raiden's Avatar
I was pulling my cam out and I think I hit the very end of the cam bearing with the distributor gear. It is the very end of the bearing, cloest to teh water pump. A friend of mine told me to get som 600grit and smooth the bur's out?
HLEP
Old Mar 22, 2004 | 12:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes you can polish it out, if it's not too bad. Just remove whatever burr got thrown up by nicking it; don't try to make it smooth or anything radical like that.
Putting the cam gear back on it makes a good handle for controlling it while sliding it out and back in.
If it's a flat tappet cam, be very careful handling it after it's out; a used cam becomes VERY SHARP on the edges of the lobes. I've seen people pick them up carelessly and have them twist in their hands, and slice the whole palm of their hand open down to the bones. Hold it by the bearing journals ONLY!!! Rollers aren't so bad about that.
Old Mar 22, 2004 | 12:32 PM
Raiden's Avatar
No, it's a roller cam..... So 600 grt, and just the bur's right? I hit it on two spots on the bottom, wish I knew how to post pic's...
Old Mar 22, 2004 | 02:09 PM
Raiden's Avatar
ok, see if this is ok or not???????? hope so!!!!
Old Mar 22, 2004 | 02:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's not too bad, I wouldn't worry about it.
Old Mar 22, 2004 | 05:43 PM
Raiden's Avatar
OK, I took about 5-10 passes over the two scratches with 600grt, then did a final 2-3 swipes with a scotch bright. I could still see the scratches, but it did knock down any burhs that were there. I could never feel any thing sticking up, but i could feel the high/low spots.
After I installed my new cam, the scratches were still visible. I think the scratches do not even touch where the cam rides I hope so!!!!!!!!
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
