r12 to r134
Old Mar 23, 2004 | 03:38 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
r12 to r134
Anyone out there do this? Does it work? Anyone ever heard of freeze12 and does that work?
I have a leak, and as usual they will use r-12 to verify it has a leak (like that isn't against all EPA regulations..) and then want to replace the compressor ($14,000,000) even though they never built up enough pressure for the compressor to turn over to find out that the compressor isn't even the problem. Then they'll want another $40,000,00 for the 3.5 lbs of r-12 to fill it back up, not including the new accumulator and new orafice tube and whatever $180,000,000 hose is the actual culprit to begin with.
Combine that with the fact that the '80 needs a new compressor for sure, and the 89 LeBaron needs one as well.
In other words I'm going to donate a few paychecks to keep cool and wanted to make sure I don't get convinced to switch to something that doesn't work.
Old Mar 23, 2004 | 03:48 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
In the long run the R134 will be cheaper. But it does not do as good a job. If it needs a major overhaul I would change over. But if it just needs freon, I would stick with the R-12.
Old Mar 23, 2004 | 03:50 PM
azvolfan's Avatar
Chris, you should throw this over to the General Tech board. you will probably come across a lot more people over there who did the change over.
Old Mar 23, 2004 | 04:29 PM
1986redbird's Avatar
spend the 234,000,000.00 for the R-12, you will be much happier in the long run. just make SURE they gaurantee the system is leak free, the Lebaron will probably be OK on 134 but the camaro's and bird's hate the stuff.
just me $.02 worth.
Old Mar 23, 2004 | 05:23 PM
OMINOUS_87's Avatar
CG
Well arent you the lucky one!?
I have done the full swap and system overhaul to 134.
Did it myslef and it works damn good, dont believe the hype that it dont work.
Dont take it to a shop, they will rape you for the work they actually do.
They most likely will not find a leak, they are hard to track down.
You will need a new/rebuilt compressor: 100$@Autozone, new dryer: 25$, new o-rings: 5$, 134 and oil: market price but its cheap, flush the hard parts, buy a new secret orrafice tube and adjust your pressure switch to a secret setting, then slap it all together.
Total parts should be less than 200$ plus an additional 100$ paid to me for the secret settings, LOL.
Call me for the fine details, all in all its pretty damn easy with the proper know how in your hip pocket.
Old Mar 23, 2004 | 06:30 PM
cg91ta's Avatar
KEWL! I'll pm you later this week and get your number
Old Mar 23, 2004 | 06:41 PM
azvolfan's Avatar
Chris,
So are you back from IAH?
Old Mar 23, 2004 | 06:43 PM
OMINOUS_87's Avatar
We actually talked about this months ago, when you told me how you had the hookup on the cheap R12 from a source of yours but you didnt feel that you would be able to do me any favors for me in the cheap hookup dept, LOL, JK! Looks like your source has dried up anyway, just like your cool breeze in the car.
But anyway, I was on the fence back then as well, and was nervous BC alot of folk on this board say how bad it had went for them, I think that they just didnt know what the hell they are doing.
When we hook up I will take you for a roll in my car and you can feel the breeze for yourself.
Results talk, not hearsay. But dammit your gonna buy my gas if I gotta roll up to BFE and lend a hand, LOL.
Old Mar 23, 2004 | 07:31 PM
cg91ta's Avatar
Yep, back from Houston...to a bad waterpump and no A/C.
Ominous, if you're volunteering help the least I can do is gas..
Old Mar 23, 2004 | 09:13 PM
stupid4901's Avatar
my car was swapped over to the r134a system. and im getting rid of the AC. So if you need any parts let me know.
Old Mar 23, 2004 | 09:26 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
I have 134a in my 91 v6 camaro and it works damn good, not as good as r12 but good enuff. the diffrence is not all that big so that you should conceder paying the price to stay with r12.
Some FYI for people that may not know. When shops test a/c, oil, p/s, atf leacks the add a die to the fluid(or gas) let the car run for some time and then get a black light to check for the die that was just placed into your car. a/c die looks neon yellow and all oil's look neon green. there are some other colors out there but i don't remember them know, i have always used those two colors. but chances are that some body had put a/c die in your car and all they had to do was look at you a/c system with a black light and know what was wrong. but if not then they where full of $hit, hence go some where else or do it your self.
Old Mar 23, 2004 | 09:45 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I converted my 91 Formula over last summer when I bought it and the compressor was empty. Bought a little conversion kit at Autozone for like $45, added an extra PAG oil shot, and it's worked like a charm ever since. I know you're supposed to flush the system of all the R12 first, but since I was trying to drive the car home from VA to Dallas, TX in mid June (I bought it off eBay) and it was empty anyway, I didn't have much choice. Still running the original compressor, dryer, etc. YMMV (Your Mileage May Vary), of course!!!!!
--- Vern
Old Mar 23, 2004 | 10:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I just got this kit today from (mcaugie007).Bought it on ebay for $45 shipped.Going to install it this weekend.
Old Mar 23, 2004 | 10:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Old Mar 24, 2004 | 09:57 AM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
Hey Chris, I have a "Leak Seeker". Just got it last night & I'm going to use it when I get home from wk this afternoon (actually 3hrs). You're welcome to borrow it if you want to. I don't live that far from you. Dunlap & I17.
Old Mar 24, 2004 | 02:03 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
the retro-fit kits are good you just have to be 100% sure you dont have a leak. just make dam sure you flush the air out of the system. did one kit on a taurus and we werent sure if we had the leaks fixed apparently we didnt so now we have no A/C in it, the goodyear tire shop here in goodyear wanted $1500 for the replacement of the r12 compressor lines/dryer and another $90 per pound of r12; hint hint... the car isnt worth $1500.
Old Mar 24, 2004 | 05:56 PM
OMINOUS_87's Avatar
Actually under my guidance I will be sure to force CG to have the system "sucked dow", vaccum for 60 mins at least.
That is the only way to do it right, no ifs ands or buts about it.
b4ccamaro
Jun 5, 2016 01:48 PM
bryanwood74
Sep 24, 2015 09:50 PM
scottmoyer
Sep 7, 2015 07:06 PM
Victor6
Aug 30, 2015 02:09 AM
jackhammer
Aug 15, 2015 10:04 PM
