strut idea
Old Feb 23, 2001 | 05:55 AM
v6-3.1's Avatar
strut idea
I got into an accident. the front had to be replaced and repainted. comming out of my driveway day after day eventually messed up the front skirt.I want to repaint the whole car and I want to keep my shine. I was wondering if I could replace the struts with those that make the car bounce up and down in the music videos (I dont want to make it bounce I just want it to raise the front of my car up while entering and exiting my driveway).I got 3 questions.
1-where can I purchase shocks like this?
2-will these shocks be good for handling also?
3-how hard is it to install?
Old Feb 23, 2001 | 09:12 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
those shocks that you refer to are called hydraulics....not something that you would want to do.. the ride in em are horrible and for the money they are so not worth the trouble.if your scraping front end then just adjust the driveway or your approach
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
CHECK OUT MY SITE http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS SUCK
Old Feb 23, 2001 | 10:53 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I believe it's illegal for a Firebird or Camaro owner to put hydraulics on their car... the law says something about it being obscene.
I should put some tech in here, eh? Visit this website for an idea: http://store.yahoo.com/corvetteforum/aa-103-sc.html
[This message has been edited by TomP (edited February 23, 2001).]
Old Feb 23, 2001 | 10:54 AM
Blue92's Avatar
About the best way to cure that problem is to just go in driveways and such, at a angle. This is very effective. Those hydraulics are very heavy from what I've seen in mags. Or you can just get a lift kit and make it look like a monster truck .
http://albums.photopoint.com/j/View?...781&p=29492901 http://albums.photopoint.com/j/View?...781&p=29492902 http://albums.photopoint.com/j/View?...781&p=29495767
"DriveHarder"
Stock 305TBI, EDL strut tower brace w/spohn SFC's on the way and wonderbar, ASCD big block hood,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
Old Feb 23, 2001 | 11:16 AM
84TransAm's Avatar
Hydraulics are mainly meant for lowriders and showing off. Looks cool in the Snoop Dogg videos, they also have bounce-offs. The front end can bounce up to around 7-8 feet. I think it's illegal for most street driven vehicles. Of course, nothings illegal until you get caught.......
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
NOW FEATURING: Holley 600 cfm & vacuum advance
Old Feb 23, 2001 | 12:51 PM
Steve89GTA's Avatar
Is this guy serious?
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Autometer Vac+Oil Temp
Old Feb 23, 2001 | 09:22 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Whadda bout airbags. They're cheaper and lighter and you can use softer springs and tune them with air......
Thats still expensive and blowing an air hose sucks.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Feb 24, 2001 | 01:52 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Yeah enter at an angle. I just put TPIS struts on mine and it was much easier than expected, but more relevant to your post I don't scrape nearly as often. If you're only scraping the air dam, you need to rig something to brace it or just put up with buying new air dams every now and then. If you're actually bottoming out your car, chances are you need new struts/shocks and to practice entering at an angle. If you STILL bottom out, there's no real solution: using hydraulics to "bounce" the front end up a steeply angled driveway would likely destroy your car. I went up such a driveway once when my 5hitty car was down so I delivered pizzas in the ROC. I backed out and actually hit my tailpipes on the curb at the bottom - it was THAT steep. So...if you see an IROC in the South Bend, IN area with little crush marks on the bottom of the pipes - that's ME!
"We lost Dale. This isn't fun anymore"
R.I.P. #3
Old Feb 24, 2001 | 03:57 PM
The ODB's Avatar
at least you know you have some options if you can't figure a way to drive in without scraping. Plus you might get in a Dr Dre video one day.
or you could go this route
I'm seriously thinking about drolics for the front of my camaro.
83 Crossfire TA
Jan 3, 2016 01:26 PM
tglennon11
Sep 23, 2015 05:30 PM
Blue419
Sep 10, 2015 01:03 PM
SG91camaro
Sep 5, 2015 10:27 PM
scotrans am
Sep 5, 2015 04:26 AM
