speedometer trouble
Old Feb 16, 2001 | 11:20 PM
lizzardking's Avatar
speedometer trouble
i have an 84 Z28 that we pulled the 305 and put in a 350 4 bolt and a 350 turbo/w shift kit.after all this we burnt up the wiring harness,but thats another problem. in the processof putting in a new harness the speedo was destroyed.my original speedo has mph and kph ,but the only ones I can seem to find are mph only.will these work? or does any one know where i can get a speedo with both?
Old Feb 16, 2001 | 11:53 PM
burnoutrpm's Avatar
why do you need to know the kph so bad just wondering???
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
Old Feb 19, 2001 | 09:08 PM
its not that i need to know that bad,its just that if im not going to replace with aftermarket than I'd like to keep it as close to factory as possible
Old Feb 19, 2001 | 10:45 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Why dont you just get a junk yard speedo?
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Feb 24, 2001 | 09:09 PM
ive checked at at least 7 diff. junk yards they only have mph only speedo's and only the 85 mph ones. if i could find a higher speed speedo i would consider it
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
mrbird
Oct 20, 2015 03:43 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
