front butterflies on carb just hangin open...HELP!
Old Feb 24, 2001 | 04:38 PM
IROCracer's Avatar
My friend has an 84 Z-28 with a stock carbed 305. The front butterflies are just hanging open....I'm thinkin there's a piece missing or something. There's a little lever on the side with a half-moon shaped slot in it that a wire is in (the wire goes to a little vacuum lookin thing). When I move this lever, the butterflies close, so I imagine there must be a wire or sprin missin off it or somethin....where the hell does it connect to and what is it?
I'm sorry to sound so dumb, but me and carbs just DO NOT get along. Any help would be appreciated.
Thanks in advance.
Kelly
If you've gotta fix it, fix it better than stock.
Old Feb 24, 2001 | 07:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's on top of the carb, it's the choke. It's supposed to be open if the motor is warm.
ICON Motorsports
Old Feb 24, 2001 | 11:28 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Yeah, that is the choke. The quadrajet that is used on our cars, has mechanical secondaries, which means that if the primaries are open, so are the secondaries. Which means that you'd have a "runaway".
Don't worry too much about it. If it doesn't die when it's cold, then you're ok. If it does, then you'll need to come across an electric kit, so you can enrich you're mixture, then let it alone, and it will lean out.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
