oil pressure guage
Old Mar 25, 2004 | 08:39 AM
firebirdsyco's Avatar
Car: 91 Firebird
Engine: V8 305 TBI
oil pressure guage
I know Gm guages are known for probs, but hopefully someone can help me specifically isolate my problem w/ a 91 firebird 305...
When stopping, my oil pressure needle will quickly drop to zero, then return to normal operating pressure. Normal driving I also get constant slight movement of needle, but at full stop, it will dive down and come back up...
Does this look like a bad sender? how can I easily isolate this problem?
Thanks in advance for the replies
Old Mar 25, 2004 | 09:13 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
First thing id do is check the oil level. Sounds kinda like an engine with low oil.
To isolate the problem youd have to mechanically check the pressure with a seperate gauge. Then you will know what your actual pressure is. If it matchs with the dash you have a mechanical problem. If not you have a electrical problem.
Old Mar 25, 2004 | 11:02 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Yeah, check you're oil; it could be a quart low. It also could be that the oil pump pickup fell of the pump. That happened to me once and it did exactly what you are describing.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
