Cam for TFS Heads and HSR
Old Mar 25, 2004 | 06:17 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I just got a set of TFS CNC 64cc Heads, and the HSR intake.
The Cam I have in the car is a Comp Cams :
Intake: Exhaust:
Lift: .512 .507
Duration: 206 216
Lobe Separation: 115.0
Is this cam a good match for this combo? This car is not a daily driver so I could do pretty much any cam. I want something that I can hear the Idle.
Thanks,
Ray
Old Mar 25, 2004 | 06:42 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
That's a really mild cam for an HSR combo. I'd run at least a 224/230 type cam. Myself, I run a 230/236 cam with my HSR and lopes pretty good.
Old Mar 25, 2004 | 06:55 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
What lobe seperation would be ideal for that setup? Before I did any research I had a local shop here regrind my stock cam close to those specs, but went with a 108 lobe sep. I will have another ground with 110, or 112. Sound good?
Old Mar 25, 2004 | 07:33 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
How about this:
Crane PowerMax
Duration: 222/230
Lift: .509/.528
Lope Seperation: 112
then with a 1.6 rocker on the Intake should put it at .540/.528
What do you think about this?
Ray
Old Mar 25, 2004 | 08:08 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Why do you want 1.6 on the intake side only?
What are your rear gears? what is your stall speed? where do you want your power band to be?
Old Mar 25, 2004 | 10:01 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Old Mar 25, 2004 | 10:03 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
This is going to be a weekend warrior, so I'm willing to do just about anything to it. I'm pretty sure I'm even gonna put a custom 6 point cage in it. My Goal is to have a 11 sec street car.
Ray
Old Mar 25, 2004 | 11:48 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Comp Cams hydraulic roller Nitrous HP series. Part number 12-419-8
-NX288hr
-2500+ stall, lower gears, good headers and exhaust
-2400-6500 RPM power band
-ADV. DURATION: 288°/315°
-.050" DURATION: 236°/248°
-LIFT W/ 1.5rr: .520/.540
-LOBE SEPERATION: 113°
Or best yet, call Comp or your choice of company and get a custom grind.
If you are getting a new cam, dont get a cam and use rocker ratio to adjust the lift. Youre getting a new cam anyway, just get the cam that has the desired lift ground in. Of course, id suggest getting the proper components to match this. or if you are REALLY feeling bold, try your luck at a solid roller setup. When it comes to power via good cam, they cant be beat. Im running a solid roller in my 355. i love it.
gta90
Sep 15, 2015 04:00 PM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
355tpipickup
Aug 13, 2015 07:35 AM
