Buzzing Choke light fades on and of?
Old Feb 23, 2001 | 05:31 PM
Stuart S's Avatar
It's weird - I didn't even know it is supposed to buzz
(86 LG4)
Old Feb 23, 2001 | 07:25 PM
Stuart S's Avatar
anyone?
Old Feb 23, 2001 | 07:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Bad diode trio in the alternator if it fades on at low RPM and mostly fades out as Rs go up.
ICON Motorsports
Old Feb 24, 2001 | 01:37 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
EXACT same problem as me. It's nice to know that I'm not alone in this world! Does the needle on your battery guage drop every so often? I've been told it's the alternator, but the test said everything was alright. So far, the only fix I have is to turn up my stereo.
Old Feb 24, 2001 | 02:07 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
please check your fuses. sounds funny, but mine did the same thing..
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
Old Feb 24, 2001 | 07:33 AM
Biochem's Avatar
Car: 2002 SOM z28
Sounds like your fuse. I have grounded the choke wire about 15 times and I have gotten a box of those damn things sitting in my console! The light will stay on and buzz. Like RB says, it will cut out the signal to the alt to tell it that the car is on, so your alt will not charge your car...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Feb 24, 2001 | 01:36 PM
Stuart S's Avatar
I removed the bulb today, hoping it would shut up, but no...
As far as the alternator, it seems to be charging as normal, around 13V...
It's annoying as anything...
EDIT: Fuse looks fine...
So, how do we all fix this?
[This message has been edited by Stuart S (edited February 24, 2001).]
Old Feb 24, 2001 | 01:39 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
When I had that problem, it was the choke relay "chattering"... I've tried to help him find the relay but he can't seem to find the convenience center. Is it in a different place than on my 84????
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro ZZ4 M5 (V-6 in a former life) -- street beast
'91 Medium Blue Metallic Z28 A4 (UB-HSTRY's old ride) -- currently broken
'99 Navy Blue Metallic Firehawk #120 M6 (99.44% stock) -- daily driver
Old Feb 24, 2001 | 03:25 PM
Hummer's Avatar
Car: 1986 Z28
Alright, newest update...I just re-checked my alternator-fine, battery-a little low, but good, and the fuses-great. Now what? Bad ground? I know I've posted on this before, but it's really getting annoying. Where would I find the convenience center? Does it have the relays I need to find in it?
Old Feb 24, 2001 | 05:03 PM
Stuart S's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Hummer:
Where would I find the convenience center? Does it have the relays I need to find in it?</font>
Beats the crap outta me...
I had it idling in the driveway in park before...after I rev it, it seems to buzz at 1200 rpm's and then shuts up when it drops back down to it's normal park idle of 750rpm's...
Then I went for a ride - it really doesn't buzz in any "predictable" manner! This is driving me NUTS!
Old Feb 25, 2001 | 10:57 AM
Stuart S's Avatar
Oh come on people!
Old Feb 25, 2001 | 02:28 PM
Vader's Avatar
Stuart,
The "Convenience Center" (I wonder what the hell GM engineers would call "inconvenient") is located under the dash and behing the radio/heater controls.
Drop the lower trim panel in the driver's footwell are and twist yourself up and around like a pretzel until you can see the backside if the swing-out "Convenience Center". Depress the release tab and swing it down/forward so you can see the relays and chimes.
Incidentally, you probably won't see that two-wire brown cord on your car unless the RPO label has the 0UT code -
0UT - Driver convenience; Annoying Passenger Eject System (requires 'T' bar roof); Standard with custom interior.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 25, 2001 | 05:04 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
hey stu, give me a buzz
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best time & mph (Naturally Aspirated): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 *This car is 100% NYS emissions legal, w/ all emissions controls!* "If you want to have a fast car, hang out w/ those who do!"
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, INSTALLATION IN PROGRESS: 10 & 15 LB&gt; PULLEYS, CUSTOM HKS RACE BYPASS, CUSTOM DUCTING W/ COLD AIR, SWAPPING TO SERPENTINE, & MANY EXTRAS! BEST TIME: 11'S I GUESS. WE'LL SEE IN SPRING!
Old Feb 25, 2001 | 06:38 PM
Stuart S's Avatar
Thanks Vader! I'll check it out as soon as the rain stops...
Justin - I'll try you later...
fasteddi
Sep 10, 2015 09:32 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
andy74
Sep 3, 2015 08:41 AM
Omega
Aug 10, 2015 12:46 PM
