engine rebuild kit
Old Mar 25, 2004 | 05:07 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
engine rebuild kit
i have an 87 350 that came out of a truck that i'm getting ready to build. i'm probably going to get a master rebuild kit from northern auto parts for an 81-85 350 since its $150(about $250 after upgrades) and the one for a 87 is about $500. it's also a truck block so it has a flat tappet cam and thats what i'l be using. the only difference would be the rear main seal and oil pan gasket right? i'l be using older style heads so the valve cover gasket isn't an issue. is there anything i'm forgetting? i just want to make sure it will work before i spend $250 on something i don't think they would take back.
Old Mar 25, 2004 | 05:10 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yeah just the rear main seal and the oil pan gasket will not be the same.
hectre13
Dec 11, 2023 08:14 AM
italiano67
Dec 11, 2016 09:21 AM
hectre13
Aug 26, 2015 08:17 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
