Accel takes out tach at 4000rpms +
Old Mar 26, 2004 | 11:02 AM
Ronny's Avatar
note this is digital dash. anyone have issues with adding a accel
stock replacement super coil and hei (50,000) volts causing the tach to not function over 4000 rpms? seems fine until the r's come up then goes to 0001 rpms. then comes back to life at lower rpms. i was told to disconnet the filter from coil to tach. have not yet done that. comments?
Old Mar 26, 2004 | 12:36 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Yeah, I had the same thing happen to me. At first I thought the coil was defective, but the replacement did it as well. I had to remove my tach filter. Mine was a 1/2" diameter by 2" tall cylinder attached to the drivers side firewall behind the distributor. I removed it and spliced the wires together and haven't had a problem since.
Old Mar 29, 2004 | 08:47 AM
Ronny's Avatar
hope that will do it. dont wanna run a 5 inch monster tach.
Hotrodboba400
Dec 10, 2019 07:07 PM
BAMiller
Sep 14, 2015 06:38 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
