HELP! emissions.
Old Feb 26, 2001 | 02:08 AM
3.1 firebird's Avatar
HELP! emissions.
I keep failing my hydrocarbons. I need .8 gpm to pass, but I keep hitting a .9.
I already did a tuneup and added"pass emissions"
what else can I do, reduce timing?
Also what is this dry gas alot of people say helps their cars pass?
Old Feb 26, 2001 | 05:19 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
You need to either change your cat, or do something to the air pump. I heard that the V6s don't always pump air, only certain times. You need to burn off your HCs some how. Do you get in your car, and just drive to the station, or do you go for a long drive then take it in. The longer you drive, the more efficeint your cat will be. Try that.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
racereese
Oct 10, 2015 09:39 PM
camarokid
May 6, 2002 08:21 PM
Jason M 91Z
Aug 8, 2001 04:02 PM
89Birddy
May 9, 2001 11:51 AM
89Birddy
Apr 23, 2001 03:48 PM
