click, click, click goes the motor
Old Mar 28, 2004 | 03:52 PM
SchwarzCamaroRS's Avatar
in my new LO5, my engine has a little clicking that accompanies the rpm... it only happens when the engine is in gear, not in park or neutral... ive heard it in other cars, so im not too worried about it, but i dont like my car makin these noises... its not lifters because in my engine equipped with a 5 qt oilpan, i have 5.5 qts in it, my oil gague says 1/8th inch over full.... the sound doesnt get noticable until about 2000rpm and gradually gets louder as RPM increases... but i dont hear it anymore because of my exhaust... WTF IS IT??
Old Mar 29, 2004 | 07:49 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You probably have a broken weld on the flexplate or a bolt may have worked its way loose.
Old Mar 31, 2004 | 01:47 AM
hmm... maybe, i hope not... i just had the motor installed maybe 2 weeks ago
Old Mar 31, 2004 | 05:51 AM
ede's Avatar
ede
is it connected to engine speed? i'd guess exhaust leak or injector tick. after that i'd look at the rockers.
Old Mar 31, 2004 | 08:50 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I second the rockers.
Old Mar 31, 2004 | 09:54 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
If it only does it when in gear, check the cover on the TC cover. If my cover is just slightly out of place, I get the same sound. Then like the others said, listen for injectors and check the rockers!!
Old Mar 31, 2004 | 10:52 AM
maybe the injectors, but why the rockers? its a NEW engine... it only has 520 miles on it and has been started maybe 50 times
Old Mar 31, 2004 | 02:07 PM
Car: 91Z
One or more may be loose, never adjusted proparly the first time?? We are just throwing ideas at you for things to check. Good luck, let us know!
Old Apr 2, 2004 | 12:03 AM
Lhorn's Avatar
Had a similar clicking when my Chevelle was in gear. Turned out to be a cracked flexplate.
BRoss99
Aug 10, 2025 05:08 PM
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
B_Dubya
Aug 26, 2015 05:09 PM
Randomtask2
Aug 26, 2015 03:34 PM
