Will my stock parts take a dump on me???
Old Feb 26, 2001 | 05:46 PM
BlueBottleJunky's Avatar
I'm in the process of a head/cam/intake change on my L98 and was wondering what kind of HP my stock lower end (pistons,crank,rods) can withstand. Also, I think my 700R and Aussie 9 bolt are possibly in jeopardy as well. My new combo should be good for 425 HP at the flywheel. I think I'm OK there but if and when I throw a 150 shot at it, has me concerned. All parts have 39k on them. Trans is '88 700R with a shift improver kit and a 3000 stall Vigilante. Rearend is the factory 9 bolt w/ 3.73s and c-clip eliminators. Will these parts be able to take roughly 550 HP? Any one out there running high horse SBs with stock trans and/or rearend? Thanks in advance.
Old Feb 26, 2001 | 06:56 PM
JETHROIROC's Avatar
I think the bottom end of the engine will be OK since it has such low miles, but you may want to take it easy on the nitrous. If the rear is a Borg Warner those are stronger than the 10-bolt so you'll probably be OK there too for awhile. I'm not quite as optimistic about the tranny, though. Do you have a good cooler on there?
Old Feb 26, 2001 | 07:02 PM
The rearend is an Australian 9 bolt....not sure if its a BW or not. As for the trans.....it came factory with a trans cooler and an aluminum driveshaft. And no, it's not a 1LE...I checked that.....no such luck.
Old Feb 27, 2001 | 06:23 AM
Nitro Don's Avatar
Ive' been running 150 shot of juice for a while.The stock bottom is holding up.The only problem is the trans & rear.When You start hooking the tires,your gunna break.When I put on the drag radials,I busted the trans 2 times in 3 months.Also broke some teeth on the pinion.
Nitro Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
TCI shift kit
Vette servo
B&M 3-4 upshift kit
TCI Trans Rebuild
2800 stall 9.5" TC
Nitto Drag radials
FUTURE MODS:
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
