Fuel Sending Unit??!
Hey, I am having a problem. I just found out that I am going to need a new sending unit. I also found out that they are a dealer only part and cost like $500. Now I just bought a new fuel pump and really don't want to have to buy another so does any one know where I can get one for cheap with out a fuel pump. I am going to school and am kind of low on cash.
Jason
1988 Pontiac Trans Am GTA
350 tpi
BEST ET 15.4
Jason
350 tpi
BEST ET 15.4
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Check the local junkyards! Those mechanisms don't go out very often so I'm sure you can pick up a good one at a junkyard!! That would be your cheapest bet!!
1986 Trans AM
305 TPI
200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.73's....oh joy) :P
Completely Stock
Soon to upgrade to a 350 converted from TPI to Carb, Edelbrock 750CFM Carb, Edelbrock Performer RPM Intake, Headman Shorty Headers, Some sort of ported heads (undecided), XE268 Cam, Moroso HEI ignition kit with external MSD Blaster II Coil and an MSD 6-AL Box!!
Current project: Keeping my 305 running until I get my income tax returns!
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
If you need a gas tank sending unit check with Jim at thirdgenparts.com. I bought one from him for $75 with S&H and it was purfect. Make sure to tell Jim that Jeff Hadlock sent you. Also, when you replace it go ahead and replace your fuel pump and pick up "net" with a new AC-Delco one. Do not get anything but a Delco one. They run about $65 about Pep-boys, the net is about $10. The gas gauge sending unit on those is rather fragile so be careful when you sre stabbing it into the tank. You never know, yoy may be able to fix your old one. I fixed mine one time before a shop mutilated it by pulling it out too fast. Email me if you want some more info.
Well I already have the fuel pump i think i did email him. I am awaiting a reply. $75 bucks, hell thats a good deal. I hope he has one.
Thanks for your help
Jason
350 tpi
BEST ET 15.4
Jason
350 tpi
BEST ET 15.4
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I got mine from www.tabertouch.com.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Jake
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
