whats a good way to lube my speedo cable?
Old Mar 30, 2004 | 06:48 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i bought a new cable, installed it, it bounces, oops i forgot to lube it and it didnt come pre lubed.. i dun want to run tot he store atm but i do have carb cleaner, k&n filter oil, motor oil and rubbing compound, lol would any of those make a good lube for the speedo cable? and if not.. what can i buy thats fairly cheap that will work?>
Old Mar 30, 2004 | 06:50 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
motor oil will work fine
Old Mar 30, 2004 | 06:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
cool thanks for the quick reply, im gonna go do that now. how much should i let run down the tube? you poor it in the end that hooks to the speedometer correct?
Old Mar 30, 2004 | 06:58 PM
Dave Y's Avatar
Engine: 4.3L V6
I would slide the inner cable out, pour some in(maybe till it stops going in, dont have to though) then slide the inner cable back in, if oil comes out before it is all the way in, good, it means the housing is full of oil
yes, from the gauge end
Old Mar 30, 2004 | 09:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds like a plan
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
beachrodder
Aug 7, 2015 04:27 PM
