mechanical or electrical fuel pump??
Old Feb 28, 2001 | 08:36 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
ok ok, as for now i'm running a 305 lg4 w/ carter 600 and a aftermarket intake manifold (& vacuum advance distrib) the question is should I go with one of those like high performance edelbrock or similar mechanical fuel pumps or one like those holley red's ?
thnx
Old Feb 28, 2001 | 09:32 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Either type of pump should work fine for you, its just a matter of personal preference. Its much easier to put in another mechanical pump if you don't want to spend much time on it. If you get an electric you will need to mount it back by the tank and use a regulator which adds to the work involved. I have a carter electric pump, I like them a little better than the holly's because they are quieter. Electric pumps are nice because you can manually turn them off and on and the fuel pressure is much more consistant.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old Feb 28, 2001 | 09:42 AM
FastBroker's Avatar
You don't need a regulator with the smaller Carter electric or the Holley Blue, I believe. Holley Blue is PLENTY enough pump for most street/strip app's at/below 400hp. Holley Red needs a reg but comes with it, I thought.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
