What is a centerbolt head? Confused . . .
Old Feb 28, 2001 | 03:18 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I have the LO3 in my 91 bird and I always see tons of parts (et. valve covers) and stuff for everything except centerbolt heads. I really would like to know what that means, lol. Also, what would be the best heads to put on my LO3 if I plan on building it up. Thanks.
Old Feb 28, 2001 | 03:21 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Just mean it uses centerbolt valve covers instead of the typical perimeter valve covers.
Old Feb 28, 2001 | 05:02 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Thanks. Could anyone explain in just a little more detail? I kinda figured that out from the name, lol.
Old Feb 28, 2001 | 05:11 PM
Neo's Avatar
Neo
That is basically it. There perimeter has two bolts on each side where the valve cover meets the head where as centerbolt has a row of four bolts raised up on top of the valve cover in a row. Sorry no pics.
[This message has been edited by Neo (edited February 28, 2001).]
Old Feb 28, 2001 | 05:35 PM
Polecat's Avatar
If I read your post correctly, you are looking for some good centerbolt heads?
If so, that's easy, get the Vortecs.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
RazorN8
Jan 7, 2022 11:44 AM
MoJoe
Sep 24, 2015 09:12 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86IROC112
Aug 21, 2015 07:20 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
