What does it cost to have your heads ported and polished?
Old Feb 28, 2001 | 04:21 PM
Dan87IROC-Z's Avatar
I am talking fully ported here. What should I expect to pay for that?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 28, 2001 | 04:27 PM
Jester's Avatar
Well..when I FULLY ported my heads it took me about 24 hours of work over 3 days. Better equipment like in a shop will be a bit faster..but still...not cheap.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Welp, the local shop here was asking 600 buckeroo's.. for that kinda dough i might as well have just bought Sportsman II heads.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Feb 28, 2001 | 04:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
"I want my car washed, polished and waxed... and I mean fully washed and waxed..."
It's impossible to predict what it will cost, because that means totally different things to different people, and it depends on what you're starting out with and what you expect to end up with.
It's like so many other things in this business, there's no fixed charge, like you put your heads in the "porting machine", put your 3 quarters in the slot, and after a while out pops a set of polished heads. I know people who would take a lawn mower blade sharpener to a head and tell you it's "fully" ported; and then I know people who will get out a buret stand and measure port volumes and match them to within a cc and flow them on a bench to within 10 CFM before they would consider turning them out as finished. I doubt you want either of those guys working on your particular heads.
You're basically going to pay by the hour. You need to find somebody whose time is productively spent while they're porting heads, and pay what they charge until they're through. Chances are that somewhere in the 4-6 hour range will yield about 90% of the possible improvement in flow on a pair of stock L98 iron heads. That should be $200-300 in most shops. So, if somebody quotes you much less than $200, you're probably getting a hack job; and if they quote you much more than $300, it's probably overkill. That assumes you're handing them a set of bare castings, any disassembly and reassembly will be extra.
ICON Motorsports
Old Feb 28, 2001 | 05:37 PM
Polecat's Avatar
It really depends on the heads. Some places you can buy heads already done. but look to spend $200-$400 depending on what you want done, and how well.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Mar 1, 2001 | 12:18 AM
johnyIROC's Avatar
Do it your damn self! It's free, and you will feel cool if you do it yourself.
http://www.sa-motorsports.com/diyport.htm
Old Mar 1, 2001 | 11:30 AM
Beefy89's Avatar
If you dont want to do it yourself,then call a speed shop and ask them.If it's more than $500 you might as well buy new heads.You can get a set of World S/Rs from www.competitionproducts.com for $500 or so,ready to bolt on.
We need Perry Mason
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
