400 guys within....
Old Mar 3, 2001 | 12:39 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
400 guys within....
Please check out the following thread and give me your input. Thanks.
https://www.thirdgen.org/messgboard/...ML/000595.html
Old Mar 3, 2001 | 04:31 PM
The ODB's Avatar
Sounds like around 400hp.
I don't really think 11.3 is all that fast for a 400cid engine but maybe that's just around here.
The cam is too big for a street car. If you want to keep the cam, then you'll need a very good converter like a vig 3600 or better. If you get the vig, then don't over-do the rear gear. For 400cid and a good stall I wouldn't go more than 3.42:1 with 26" tires, or 3.73:1 with 28" tires. The vigilante will help much more than gears.
That engine will want the Hooker Super Comps 1.75" full lengths and duals.
A good head porting should wake it up a lot.
I just use the stock radiator and stock single electric fan on my 383 and never have a problem. I would give the stock parts a chance. They might be enough.
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
Street Lethal
Aug 14, 2015 08:25 PM
