What's the point of block filler
Old Mar 3, 2001 | 10:59 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Block filler probably makes the block stiffer, right? Does it go in the coolant area or what? Does it affect the cooling abilities of the engine? Is it lighter than coolant would be? Just curious. I'm not actually thinking of using it, but was just wondering what the benefits/drawbacks are. Thanks
Old Mar 3, 2001 | 11:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You fill the water jackets in the block with it. It's basically like concrete once it hardens. The point is to stabilize the cylinders in the case.
If you fill it completely, you obviously no longer have a cooling system in the block. Some people fill them partway which lets them still have water circulation to where they can run it on the street. It's mostly for strip-only cars though.
ICON Motorsports
Old Mar 3, 2001 | 11:06 PM
Is there some horsepower or torque level where it becomes advisable to use it?
Old Mar 3, 2001 | 11:19 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RednGold86Z:
Is there some horsepower or torque level where it becomes advisable to use it?</font>
When four bolt splayed/studded main caps and main cap girdles no longer hold the bottom end together, it is advisable to bondo the block of your next replacement engine. A properly prepared SBC will hold together pretty well with 850+ HP coming out the crank at 8,500+ RPM, so unless you're pushing those limits, don't even consider it.
(HINT: NASCAR engines have a complete cooling system.)
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Mar 3, 2001 | 11:42 PM
The ODB's Avatar
another advantage.
the reason for reverse-flow cooling was to cool the heads first and keep the bottom of the bores warmer. The warmer bore stays more round and presents less drag to the piston. Keeping the block stiff and at an even temperature is to your advantage.
For power production, the idea is to keep the oil warm and the coolant cool.
Old Mar 3, 2001 | 11:57 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
yup the engine guy always said hot oil, cold coolant makes a happy motor!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Nick McCardle
Sep 10, 2015 08:36 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
