Timing Chain Htting Cover?
Old Apr 5, 2004 | 04:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just started up my new 383 and it sounds like the timing chain is hitting the cover. The timing cha was reused since it was absically brand new and it was k On the od motor. But this time I went with one of those cheap shiney covers rather then the old stock one WHICH I THREW AWAY could this be? Anybody else have trouble with it?
Old Apr 5, 2004 | 05:47 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What type of cam are you running. The dowel pin may be hitting it. You will need to fix that because you will wear a hole in your cover in no time.
Old Apr 5, 2004 | 05:48 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
LPE cam. Its all I think cause hats where e noise coming from. Any ideas?
Old Apr 5, 2004 | 06:22 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Did you remember to re-install the cam retainer plate? Is that cam an LT1 style cam?
Old Apr 5, 2004 | 08:09 PM
Damon's Avatar
Yeah, gotta use the retaining plate AND a factory roller cam-style timing chain (not an old flat tappet style chain set).
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
