size of fuel line tube?
Old Apr 7, 2004 | 01:27 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
you know the main fuel line? where it screws into a rubber hose, then about a foot later, screws back into the steel line? well what size is that rubber hose?
reason i ask is i need to cut that hose, install a t fitting that will run to my 1/8" inlet on my fuel solenoid.
Old Apr 7, 2004 | 02:18 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: size of fuel line tube?
Should either be 3/8 or 5/16. You should have one size of each. Inlet and outlet lines.
Old Apr 7, 2004 | 04:35 AM
ede's Avatar
ede
stick a wrench over it and you'll know
Old Apr 7, 2004 | 10:35 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
is it measured by outside diameter?
Old Apr 7, 2004 | 10:46 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The hose is measured by inside diameter. The two metal lines are 3/8" for pressure and 5/16" for return.
Old Apr 7, 2004 | 10:49 AM
ede's Avatar
ede
hard line would be measured by the od soft lines by the id
Old Apr 7, 2004 | 11:07 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
if the metal lines are 3/8" (the one to feed the TBI) is that what size the rubber hose part is as well?
Old Apr 7, 2004 | 11:12 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i checked the nos website, and they only have a t fitting for 5/16"
would i be able to pick up a 3/8" 3/8" 1/8" tee fitting?
http://www.holley.com/HiOctn/ProdLin...OSCA/BrHT.html
Old Apr 7, 2004 | 11:16 AM
ede's Avatar
ede
look someplace that deals in hydrolics, like parker store. you can pretty much get the parts and fittings to do anything you want.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
toronto formula
Nov 10, 2015 06:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
