Lets play solve my problem!
Old Apr 7, 2004 | 05:43 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
just finished a cam swap, got everything all buttoned up. when i got to start it, it will start, and revs shoot to the moon with the brown distributor wire plugged in, if i unplug it, it starts, goes really rough, but it dies before theres enough time to time it precisely no vaccum leaks, what else could it be?
Old Apr 7, 2004 | 08:46 PM
formula2fast's Avatar
Car: 87 Pontiac Firebird Formula
Engine: 355 SBC-Thats all I can say or they will break my legs.
Transmission: 5 Speed
sounds like your timing may be too far off...Re-stab the distributor. Once you unplug the brown wire, that takes the computer control out of the equation. The it is running off of true timing. I would put the motor at TDC again, and drop the distributor again, it sounds like you have it a tooth off.
Old Apr 8, 2004 | 04:08 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Not another TOOTH OFF debate... I'd say turn the distributor a little each way, then fire it up, being a "tooth off" would mean you would just have to turn the distributor that much farther to get the timing right. I too think it's timing, or vacuum, but you say you have no vacuum leaks.. I'd double check.
Old Apr 8, 2004 | 04:32 AM
ede's Avatar
ede
a tooth off
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
