Tire wobble
Old Mar 4, 2001 | 10:33 AM
Hulk0202's Avatar
Tire wobble
I just rebuilt the front end of my 91 FB. Now before I did this, anytime I locked my brakes up, the front tires would wobble very bad until I slowed down to like under 20. I thought that rebuilding the front end would fix this, but it didnt. Can anyone tell me what the problem is. I didnt replace my center link or pitman arm, they both seemed fine. Could it6 be in the steering box, or maybe the rag joint?
Old Mar 4, 2001 | 11:14 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Could be just about anything you didn't replace.
Look at the rag joint, have someone move the steering wheel back and forth just a couple of inches to "take up the slack" while you look at the steering linkage.
This really needs to be done while there is a load on the front end so you need to have the car on ramps so the front tires are not hanging.
Rotors being warped would do the same thing.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
[This message has been edited by Engineboy (edited March 04, 2001).]
Old Mar 5, 2001 | 10:24 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I was thinking warped rotors. Is there much play in your steering? If not, its probably the rotors.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Mar 5, 2001 | 11:03 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Gotta agree with the last post....had a similar problem, new rotors and pads cleared it up.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Mar 5, 2001 | 11:58 AM
Hulk0202's Avatar
Aha, but.....I replaced my rotors and calipers less then a year a go.
Old Mar 5, 2001 | 12:34 PM
93ND500's Avatar
I would still check them out. Rotors can warp at any time. I have seen them go in as little as a month.
1993 C1500 Indy 500 Edition
1992 TA TPI setup
Stock motor, new one being built now.
www.geocities.com/wsleigh
Old Mar 5, 2001 | 12:40 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I have also had the misfortune of getting bad ones out of the box from the store. That was not a fun day...
KAM
Old Mar 5, 2001 | 12:58 PM
85berlinetta's Avatar
It is your centerlink. Last summer I had the same exact problem. I replaced the pitman arm too. The problem didn't get better untill I replaced the center link. Replace the center link. It didn't take me more than 20 minutes.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
