400sb and oil pan question
Old Mar 4, 2001 | 06:39 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
Is the oil pan a factor when installing a motor into an F-body. Are the bends and such the same for all sbc pans? I know the rear main seals is one difference. The 400sb I have already has an oil pan but I want to know when I go to drop the motor in that it will fit my bird. Thanks
91 Firebird 305/TBI - cam:.420/.442 204/214 - Hooker 1 5/8" headers - TFX PaceSetter Cat-Back - 3.42's Auburn Pro Posi - ASCD Ram-Air hood - Polished Formula Wheels w/Futura's - Open element - .5" Corian TB spacer - Lakewood LCA's - Hotchkis Lowering Springs - KYB Struts/Shocks - 14.78 @ 97.5 mph(G-Tech) - MacEwen MotorSports Whiteface Overlays - 412ci sb waiting to go in this spring.
My Homepage
Old Mar 4, 2001 | 07:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pans vary greatly with the chassis they came in.
I have the old 6-quart-system Z28 pan on the 400 in my 83, it fits everything fine. It absolutely requires a windage tray however. There's no way to guess whether whatever pan is on some random 400 will fit one of these cars or not. My gut guess would be it would not, at least not certainly enough to go to the trouble of building and installing a motor expecting it to fit.
ICON Motorsports
Old Mar 4, 2001 | 07:23 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Looks like I will be getting a new pan. I was pointed towards a moroso 6-quart p#20180 $118. Any other pans that would work for less money?
Old Mar 5, 2001 | 10:19 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
A plain jane SB chevy one will fit. Mine does. You can get a chrome stock one from PAW for 40 bux.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Mar 5, 2001 | 01:05 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
So a plain jane pan for an f-body will work or any for a sbc? I have a plane jane chrome one for a sbc on the motor now.
Old Mar 5, 2001 | 01:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ones for trucks and full-size will not fit. The one that fits in an F- or G-body will fit anything else. Most of the chrome ones like Spectre or Daytona are that, so they can be as universal as possible. So you're probably OK. Of course, you also need to make sure that it's for the early style dipstick tube arrangement and rear-main-seal design; so for instance one that will work on your 91 obviously won't work on the older motor.
ICON Motorsports
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
