blown engine why???computer???
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
hi i blew a brand new motor because a fuel lock append in 2 cylinder so when the piston tried to compress the cylinder full of gas i bent 2 rod and the crank. its waranteed, the guy is actually rebuilting me a 350 instead on the 305 that blew . the guy sait that it was the injector that was wrong but why the where ok before and 2 of them would broke at same time possible??? other guy at the local auto part think that is the computer that is going crazy possible have any answers??
and how to check in injector are good???
Transmission: 4L80E/4L80E
A completely different picture comes to mind when I think of blowing an engine - like things poking out where they don't belong.
Leaking injectors can flood a cylinder, but only when the engine isn't running. To test, you have to have the injectors out of the manifold, and apply pressure - either on a bench, or still hooked up to the fuel rails and "hot wiring" the pump to stay on with the key in the "on" position.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: blown engine why???computer???
colton_carlson
Mar 8, 2019 12:21 PM
