Where to get motor mounts?
Old Mar 5, 2001 | 05:35 PM
Jason M 91Z's Avatar
I have my front control arms out, and since this is my only chance to change the motor mounts, I might as well. Any idea where I can get a good set of rubber ones, or do I have to order from a dealer? If its a dealer part, anybody know the PN and price? TIA guys. Also, will those ES poly mounts work?
-Jason M. 1991 Camaro Z28
Old Mar 5, 2001 | 05:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Poly will work if you want to go that way. Any part store should have the rubber mounts. You're right, now is definitely the time to renew them.
ICON Motorsports
Old Mar 5, 2001 | 09:16 PM
bad camaro RS's Avatar
yes do it now or youll kick yourself later i jus installed poly mounts last weekend what a pain in the a$$
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10.9 to 1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
accel 8.8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos to be installed soon
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
