Can I wire a dual fan setup off a single fan connector??
Old Apr 10, 2004 | 02:16 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I have a 91 Camaro RS with a single fan setup. Can I wire a dual fan setup off the single plug?? Is it safe or will 2 fans cause too much of a load??
Old Apr 10, 2004 | 02:26 AM
owned's Avatar
It's marginal.
For a while, I had the dual fans set up off of one relay. It always worked fine, but I found after a long trip, the relay had gotten so hot it had melted together with the plug.
I would just get an aftermarket relay able to handle the load.
Old Apr 10, 2004 | 02:02 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Why do you want to change over to the dual fans out of curiosity?
Old Apr 10, 2004 | 06:35 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I dont know but you should change Performance in your sig to Suspension.
Old Apr 10, 2004 | 07:42 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
good point I guess I should!! But the reason I want to change it to a dual fan setup is for better cooling plus I'm in the process of putting together a TPI swap. I figure If I can wire things like the dual fan setup in now it will save me time later because I will already have it in place.
I see no draw backs to haveing a dual fan setup with a TBI engine anyways. I figure the engine will cool faster with 2 fans running resulting in shorter fan running times.
Old Apr 10, 2004 | 07:56 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
how is that 89RsPower! ??????? I hope your happy now!!!
:rockon: :yourock:
Old Apr 13, 2004 | 02:18 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
i wired my fans up together for better cooling. i have never had any problems with it and the cooling is far superior. don't know why it wasnt designed that way in the first place.
Old Apr 13, 2004 | 09:09 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Remember that some single fans can actually out flow a dual fan and cost less.
eightsixseven
Dec 16, 2024 01:50 PM
onefreakz
May 14, 2018 12:15 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
86White_T/A305
Aug 17, 2015 12:16 AM
