edalbrock setup??
Old Apr 11, 2004 | 12:14 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
edalbrock setup??
ok i was looking though my summit racing catolog and i saw edalbrock was selling this combo deal a new carb intake mainfold and a cam for like 539.99 and i was like thats not tha bad of an idea unless any one's herd bad things about this i would like to know cause i need a new carb for my 350 in my camaro cause it's getting old so i think this would be the best way to go correct me if i'm worng
Old Apr 11, 2004 | 12:46 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ewwe edelbrock stuff ! A better kit if thats what your into (kit power) would be a #300-502 Systemax kit $332.99 and you could use any carb you wanted. Of course if you really wanted to make power #300-503-1 if you have $1400 burning a hole in you wallet. Ive actaully used this kit in a 64 Impala with a 750VS carb and it worked very well. Very, very, very well.
Old Apr 13, 2004 | 12:48 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I didn't purchase the cam, but I did install an Edelbrock 4bbl carb & aluminum intake on my 69 nova.
It gave much better throttle response & more torque than the old cast-iron & quadraject 4bbl.
Also, the electric choke is very nice to have.
However, I will mention that, in my experience, the electric choke carbs come tuned very lean. If you are building something you want to be quick, you will want to upgrade the step-up springs & rods (which will cost atleast another $40+).
Just my opinion.
Hope this helps.
Old Apr 13, 2004 | 02:47 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Edelbrock cams are junk, there carbs are pretty bad too. I wouldn't use any edelbrock stuff unless it was an intake.
Old Apr 13, 2004 | 05:18 PM
86'Bowtie's Avatar
Car: Hugger Orange Camaro
Yeah, I was always told to stay away from Edelbrock carbs,
not sure on the cam, can't say from any experience.
Although, I do run a Victor jr. intake on 2o2 Performer RPM heads!
I'm pushin' somewhere into the mid 400's as of now, that's also w/ all the engine work, rear end, and basically race ready car.
Old Apr 13, 2004 | 09:58 PM
ljnowell's Avatar
Nothing wrong with edelbrock stuff. I use it, a lot of people around here use it. Personally I've never had a better card, and would NEVER buy a holley. But i wont say they are junk, Ive just never had a good experience with them.
Old Apr 14, 2004 | 05:35 AM
ronterry's Avatar
Car: '94 Corvette
'86'Bowtie' your not the only one running a Victor Jr. on RPM heads, however I'm using a CompCam with this combo.
Also running a Holley 4150 on top of all this stuff
Got my feet on both sides
Ron
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
