Need Help Chossing a Cam
Old Apr 11, 2004 | 08:24 PM
KillerRS's Avatar
So far these are my plans
327 billet crank
H-beam rods
Forged pistons .040 over
10.5:1 compression
Vortec heads modifided for larger lift
650 DP Demon Carb
Msd Pro-billet
250 shoot Nitrous
Can someone help me choose a cam. Demon recomends a max 240* duration. I want to run the largest cam i can. I also would like around a 3000 stall.
Im still tring to figure out which intake to choose, but im probably going to get a super victor so i can run a direct-port nitrous.
Oh and i want a rough idle
Old Apr 11, 2004 | 09:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
First things first, 10.5 is generally excepted as the limit to comfortable compression of cast iron heads. You say "machined for more lift." What exactly did you do to them?
Ive got an Isky Solid roller, it will give you a choppy idle. Its a billet steel cam and is probably too much for you. Call Comp Cams and get a custom ground solid roller. Something with high 240/low 250 int/exh (respectivly) on a 113-114° LSA. Get high .500's lift. That will wake things up.
Old Apr 12, 2004 | 05:45 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Here's a street cam thats just right for a lil 327 on nitrous.
Crane F-278-2
I would not use a Super Vic for this motor. Its too big of an intake. The Super Vic Vortec manifold is really intended for a high(er) rpm race motor. You'd give up a lot of torque and gain little or no hp.
I would use a Edelbrock Performer RPM or a Professional Products Crosswind (vortec) dual plane. Both can just as easily be plumbed for A direct port Nitrous system.
I would use a Holley 750cfm carb #4779.
A Motor with a dual plane manifold and high stall can tolerate a little larger carb and pick up some top end ponies. the Holley is a good match to a performer RPM manifold. Its a tried a true carb, stock #70(pri) -#80(sec) jetting will do fine.
You'd need to select a converter with a little higher advertized stall than 3000 to actually see 3000 rpm stall behind a 327. Most converters' rated stall speed is rated behind a 350CI motor. I would look for a "3500 Stall" converter.
The combination of these parts would perform real nice on or off the juice.
At the 250hp nitrous shot level you will need to use 100% 110+ octane race gas and retard the ignition timing a bit. Advancing this cam in the motor a little further than specified on the cam spec card (about 4 more degrees) will enhance the power when on nitrous too.
Old Apr 13, 2004 | 02:22 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Re: Need Help Chossing a Cam
Originally posted by KillerRS
327 billet crank
Who made your crank? Why dont you sell it and buy a forged one and spend all the extra $$ on parts???
Old Apr 13, 2004 | 02:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
327 billet crank
That what i said. What!?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
