not as powerful as it should
Old Mar 6, 2001 | 09:34 PM
D-Rock'87GTA's Avatar
My friend who knows a lot about cars drove my 87 GTA with a 350 TPI and he said that it isn't as powerful as it should be. He said he drove some 305's that were as powerful as my 350. I was wondering if it is a 350 (I am pretty sure it is) and it also hesitates when I drive it I am gonna replace the fuel filter soon.. It has 119 thousand miles on it. what else should I do to it to make it run right.. thanks
Old Mar 6, 2001 | 10:40 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
First find out what engine you have. Look at the eighth digit on your VIN number. It should be a number '8' if it's the TPI 350 (B2L).
Letter 'F' if it's a TPI 305 (LB9).
As far as power mods, there's a zillion other threads pertaining to that, and people who could point you in the right direction. I know enough about the TPI's to be dangerous, but not really for power modding advice (i'm a carb guy).
DR Stevens
Car #1:
1984 TA L69 H.O.
750 cfm Q-Jet reman. by Holley, 700R4 /w/ Superior shiftkit, 3.42 lim.slip, 4whl disc, underdrive pulleys, Accel HEI, experimental dual snorkel /w/ hood louver, some sort of weird 3" exhaust soon to be replaced
Car #2:
'91 Firebird/Formula LO3
all stock except K&N air filter (but not for long!!)
Old Mar 6, 2001 | 11:53 PM
R.O.B.'s Avatar
With over 100k miles on it, replace the timing chain. This will wake that motor up.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Mar 7, 2001 | 12:59 AM
The ODB's Avatar
it may have a low compression replacement engine in it from autozone or some other parts shop. Check the block & head casting numbers to see what they are.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
