Mini Ram II Problems
Old Apr 15, 2004 | 06:15 PM
BryceW25's Avatar
Car: 87 Z28
Engine: Mini Ram II, 113 heads tpi
Transmission: 700-R4
Just installed the Mini Ram II intake on my 87 Z28, i set the timing at 10 degress, and it backfires once and while, and also back fires up through the intake, what should i do, do i need a new prom or somthing dealing with the computer?
Old Apr 16, 2004 | 12:50 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Sounds like a timing issue. Check your plug wires and cap for proper plug routing.
Old Apr 16, 2004 | 07:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like it needs more fuel. Some chip work would be a good idea. You might want to just bump the fuel pressure up a little and see if it helps.
I'd recommend leave the timing alone. Being a degree or 2 off of optimum won't cause backfiring.
mddaniel
Sep 8, 2015 05:16 PM
gixxer92
Sep 1, 2015 04:32 PM
Brendankup
Aug 30, 2015 01:46 PM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
