rattling noise at low rpms
Old Apr 17, 2004 | 07:57 AM
red91formula's Avatar
Car: '91 Formula, '00 NHRA Trans Am
well, lets see if you guys can help me with this...I've got a '91 Formula, 5.0 T.B.I, automatic, and I've been having this rattling noise at low r.p.m's only, after the engine warms up (mostly at idle)...when you step on the gas hard enough, it clears right up.
when im in park, thats when its the loudest...when i shift into drive or reverse, it gets quiet again. if i have the A/C or heater on, once again, the rattling stops or quiets down considerably.
it sounds like its coming somewhere from right behind the pulleys, in the water pump area. i have replaced the belt, tensioner pulley, and checked rest of the pulleys...nada.
to give you a better description of this noise, when i pull into a car wash, my car almost sounds like a large diesel truck (due to the echoes)
any advice would be greatly appreciated
Old Apr 17, 2004 | 09:27 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can pinpoint exactly what is making the noise - JUST BE CAREFUL! Take a long screwdriver, put the handle end against your ear, and put the blade end against various engine parts. The vibrations will transfer through the screwdriver, vibrate your eardrum, and are very loud in your ear. Really helps pinpoint exactly what - you'll really know when you hit the right spot. I have also taken the antenae off and used it, it's very long and works great. You just have to BE CAREFUL that you don't stick a moving part, or jam the thing in your ear! Places like Harbor Freight sell auto stethescopes for like $5 too - but when in a pinch, the antenae works wonders.
Old Apr 17, 2004 | 12:58 PM
Thanks, I'll give it a try
Old Apr 17, 2004 | 03:01 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
sounds like an exhaust heat shield.
Old Apr 17, 2004 | 03:42 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I was about to say what flyit said.. i'd check any manifold heatshieldes and heatshields on the cat, I had a heatshield on my cat break loose and make horrible noise..
Old Apr 18, 2004 | 03:10 AM
SchwarzCamaroRS's Avatar
mine does that too, the vibration i mean... its exhaust hitting random parts.. trans cooler lines, exhaust manifold heat shield... just make sure everything is tight on the shield and seperated down below and it will stop
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
Jake_92RS
Aug 17, 2015 09:42 AM
