how do you check codes on a obd 2 car.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Well actually its a 95 jimmy. wasnt sure if I could do like the Z since its a 95.?
Any input.? Thanks
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf.)
www.go.to/TPI383
[This message has been edited by TPl383 (edited February 24, 2001).]
Any input.? Thanks
Chris
536 RWHP 569 FT LBS
www.go.to/TPI383
'95 is an intermediate model, not the same connector as the standard OBD II, although it is an OBD II system. You may need what is called the "GM Special" 16-pin cable for the scantool, so check on that before you buy anything. The OBD II interface on my dad's 95 s-10 is different from the one on my '98 Blazer. Hope this helps.
Car: Take
Engine: Your
Transmission: Pick
You can also tell by where the computer is. If the computer is under the hood, its OBDII, if its under the dash, its OBDI.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
