Will I get beat by a civic with this combo?
Old Mar 9, 2001 | 12:50 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
Hey, I'm just looking for opinions. I,ve got the 330 hp 350 HO crate motor with vortec heads and a 9.1:1 c.r. The cam specs are: .435I, .460E, 212*I, 222*E @ .050. I have an air gap intake, 600cfm double-pumper, 1 5/8" Hedman full-length headers, Accel replacement HEI and Super coil, and MSD 8.5mm wires. I'm putting a T56 behind it as soon as I get the cash. Will this car be a dog at red lights and only good above 4,000 rpm? Or will it still make good low-end torque? Will it beat a civic light-to-light? What do you guys think?
Thanks for your opinions.
Old Mar 9, 2001 | 01:30 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Depends on what's in the Honda. I was over at a Pro Stocker friend's house this week and he
sold one of his old Doug Nash 5 speeds to an import racer. These guys use rotary engines that develope peak HP at 14,000 RPMs.
They line launch at 9K RPM's, and do 1/4's in under 9 seconds.
They put this all in a car that weighs less than 2000 pounds with driver...
See ya at the Gaternationals!
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
Old Mar 9, 2001 | 03:10 PM
Polecat's Avatar
The cam you have is pretty mild. So it will make low end grunt. The larger the numbers in the @.050 range, the higher it will start and end. You setup should beat the Civic as long as he isn't spraying alot.
Good luck!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Aug 15, 2002 | 03:07 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
huh????
I have seen rotories that can handle it... but is it good for it doing that.. not really
most rotories you see will ppl will not spin them past 9000 rpms or so
Old Aug 15, 2002 | 03:22 PM
JR305's Avatar
I agree with Polecat. With that cam you should see a pretty good amount of low end torque.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
armybyrd
Oct 24, 2015 06:59 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
roysatikas
Sep 22, 2015 08:15 PM
