Double Head Gaskets?
Old Mar 9, 2001 | 02:07 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
Who has doubled up head gaskets, and are there any side effects? Or what about steel shims? The thickest gasket I could find is .051 Thanks
  • 412ci/sb
My Homepage
Old Mar 9, 2001 | 02:29 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I've used doubled head gaskets before on a BB Chevy engine used on the street with occasional 1/4 mile blasts.
Never had a problem at all!
Now if you read some of the stuff written by folks like Speed-O-Motive, they talk about how the quench is destroyed, detonation is more likely, etc., but it sure wasn't the case with me.
Email me privately, I'll give you some more 'poop'. I KNOW you'll be interested.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited March 09, 2001).]
Old Mar 9, 2001 | 11:19 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
I agree with speedomotive, quench area is very important for power production. If i were you id take the opportunity to grind any sharp edges in the chamber, (that means pistons or head) and make everything completely smooth, this means valve reliefs, spark plug block, the outside edges of the chamber on the head, etc. not only will this knock down your C/R a bit, it will also reduce your chances of detonation substantially
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
