Will 1.6 rockers fit Vortech heads?
Old Apr 19, 2004 | 06:26 PM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
Has anyone put 1.6 rockers on Vortech heads? I was wondering if pushrod hole is clearanced enough? It's easier to ask than to take covers off & find out they won't work.
Old Apr 19, 2004 | 06:50 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yea they will fit but it depends on which ones you get. You will need narrow body ones. Also, don't forget to check for coil bind if you will be getting close to .470" lift.
Old Apr 19, 2004 | 07:02 PM
87tpi7749's Avatar
Engine: 5.7L
I was planning on cheap stamped steel, replacing ones on HT383 crate motor, relatively small camshaft.
Old Apr 19, 2004 | 08:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Cheap stamped steel "1.6" rockers will probably end up providing less lift than real 1.5s.
I wouldn't waste the money, just to put the same garbage back on.
midge54
Dec 27, 2019 04:14 PM
Cameeeero
Sep 18, 2015 04:00 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
