engine misfire
Old Apr 19, 2004 | 09:54 PM
Z28Stud's Avatar
Car: 86 Z28
Engine: 454 big block
Transmission: 6 speed
engine misfire
i am a automotive technition and i just rebuilt my 3.1 liter LHO and placed the motor back into the original car which is a 1990 camaro RS and the motor misfires at idle and has no power when driveing it. it has good compression in all cylinders and a good blue saprk, all new wires, cap and rotor and plugs. the gas is good in the tank. i checked all my injectors and they are ok. the check engine light is not on. i have pulled all my hair out trying to fugure out what is wrong if any one has a idea please help me thanks.
i have since done a running compression test on the #1 cylinder and i am getting a reading of 100 LBS i think i should only have around 80 LBS. the #1 cylinder is my problem i have found out but what it is i`m not sure.
Old Apr 19, 2004 | 10:13 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
If you have good compression on all cylinders and you are positive the injectors are spraying fuel make sure that you don't have 2 plug wires crossed.
pwood02's Avatar
Car: '86 Trans Am
Engine: 355
You did double check your timing and wire routing right? How is the fuel pressure, could dirt have gotten in the hose while it was off? Just a few things to try and help you out of your slump, good luck.
Old Apr 20, 2004 | 05:16 AM
ede's Avatar
ede
i'd look at cam timing, crossed wires, vacuum leaks, rocker adjustment
Reddeath210
Oct 6, 2015 08:20 AM
mdtoren
Aug 23, 2015 12:52 PM
db057
Aug 22, 2015 08:17 PM
mdtoren
Aug 16, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
