Noisy lifter
Old Mar 9, 2001 | 10:31 AM
Tab92bird's Avatar
Noisy lifter
My #7 exhaust lifter has always made a little noise, so when I had to take the intake manifold off because of a leak I decided to replace it. Now, the #7 lifter is fine, but #4 is REALLY bad. I'ved tried adjusting the lash to compensate, but after a few seconds it just gets bad again.
My question is, do I have to replace the d*mn thing, or can I just let it be? Is there anything I can do to quiet it down while it's still in the engine?
Thanks,
Brandon
White '92 Firebird w/ 305 TBI. Open element w/ non drop base, increased fuel pressure, TBI spacer, Hedman Hedders & y-pipe, no cat, cat-back exhaust
Old Mar 9, 2001 | 11:18 AM
82RECAROTA's Avatar
Old Mar 10, 2001 | 11:21 AM
Tab92bird's Avatar
Well, at $11 a pop, I can't afford to replace all 16. I know it got a little dirt in it, because this problem didn't exist before I took off the manifold.
Also, can you tell me how would I know if it's the rocker arm that's bad?
Thanks,
Brandon
Old Mar 10, 2001 | 05:45 PM
Tab92bird's Avatar
btt
Old Mar 10, 2001 | 08:11 PM
82RECAROTA's Avatar
Old Mar 10, 2001 | 09:24 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Well, I don't know what anyone else thinks about this, but if you think it is just dirt that got into it, the lifters can be disassembled, cleaned and reassembled. I've done this in the past with good results, but only on my daily driver (2.5 4 cylinder), and my dad's truck (3.9 Dodge V-6).
They aren't difficult to rebuild, the hardest part is getting the plunger out of it (they usually have some oil buildup in them that keeps it from springing out), then putting the clip back in that holds the thing together.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand.
Starting to look like the Kicker poster child!
ASE Certified Master Tech
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
