Misfiring, running real rich and, at a loss.
Old Apr 19, 2004 | 10:57 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Recap...
I recently had dummy cats installed and the car ran fine. I parked it at work for about an hour and a half. It started up fine but when I got to a light, the idle was crap and it seemed to be misfiring.
I just scanned it and these are some of the significant results.
*all closed loop, no trouble codes.
- O2 sensor at idle, .800 mv range. (I know that is rich but it doesn't set a code).
- O2 seems to work fine above idle. Meaning that it fluxuates between lean and rich.
- Block learn is 108.
- Integrator in 80.
Two problems that I know of are that my passenger side header collector gasket is leaking pretty bad and, while investigating a low "thubthubthub" sound, I noticed that the bracket holding the ignition coil was loose. A quick check revealed the intake manifold bolt to be loose. Even though I tightened it, the engine still seems to be misfiring.
Besides the obvious, should I be looking into anything else?
Any push in the right direction would be greatly appreciated.
Scott
P.S. And just for poops and giggles, I got a flat from a nail in my new tire.
Old Apr 20, 2004 | 01:47 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
With the fuel trim maxed out I would look for a stuck open injector or some other way for unmeterd fuel to be sucked in. Also make sure the ignition system is ok.
Old Apr 20, 2004 | 03:27 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Am I correct in assuming that you mean plugs, wires, cap and rotor and nothing else?
Two more questions:
1. How do you check for a stuck injector?
2. Could the fuel vapor canister cause a problem like this?
Thanks again.
Old Apr 21, 2004 | 01:10 PM
eric305TPI's Avatar
I would pull all of the plugs and for any that have more soot on them than others. The evap canister could cause a problem like this if it was full of fuel and the purge solenoid was stuck on.
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tmellott89
Aug 16, 2015 02:58 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
