Vader or anyone who REALLY know their stuff.....inside
Old Mar 8, 2001 | 12:12 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
ok...i dont know the whole story...im posting for someone who was too lazy to set up an acct here.
he has a SD TPI, 91 formula 350.
it wont idle for nuthin. they checked the timing it was at 16...they lowered it to 10....played with the TPS for 6 hours.....will not idle unless you turn the screw down to lower the power or somehting....i dont know really....if you have any info...or help/suggestions please email him @ codyfirebird@home.com
Thanks Guys
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Mar 8, 2001 | 07:00 PM
ede's Avatar
ede
when you say "he" played with the tps do you mean he adjusted it? if not he shouyld set it with a volt meter and i'd look at the IAC, plus make sure it has a good tune up.
ICON Motorsports
1st & 3rd
Old Mar 9, 2001 | 12:28 AM
Car: 90 Camaro RS
Engine: 305 TBI
yes he set it....at what it was supposed to be...i have a tbi...i dont know off hand what it is...but he does...and that what he set it at. it is throwing no codes also. tune up has been done.....basically he has no power or anything after 3200. and it idles really bad...i suggested IAC too....thanks guys
Old Mar 9, 2001 | 03:07 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Maybe the cat is plugged? No power over 3000 rpms is typical of that. What kind of mods are on this car? Or is it stock?
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 9, 2001 | 03:32 AM
Car: 90 Camaro RS
Engine: 305 TBI
not sure what the mods are...but its pretty thoroughly modded. htanks kev
Old Mar 9, 2001 | 10:52 AM
Blade's Avatar
I suggest you also read this...
https://www.thirdgen.org/messgboard/...ML/006484.html
Old Mar 9, 2001 | 12:15 PM
Car: 90 Camaro RS
Engine: 305 TBI
well...i didnt know where to get Vaders email...didnt look very hard...but i wasnt singling him out....see topic...."Vader, and anyone else who really knows there stuff"...i was just emphasizing the fact that it was a mind boggler inside....and help was needed.
thanks for your input though blade. ill be in vegas this june....hopefully
Rick
Old Mar 9, 2001 | 05:55 PM
ede's Avatar
ede
to e mail a moderator click on his name at the top of the board he moderates
ICON Motorsports
1st & 3rd
Old Mar 9, 2001 | 08:36 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The biggest "mind boggler" here is what the heck he has, and what the heck its doing. If he is too lazy to set up an account and tell us "whats up", then I guess I'm too lazy to help. Sorry.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 9, 2001 | 08:49 PM
Car: 90 Camaro RS
Engine: 305 TBI
either im taking this personally or you guys are just really harsh and (not)helpful. i have experienced this myself with my VATS trouble too. Granted some posters are "spooked" into thinking helping clueless people with VATS is bad. BUT cmon, whatever happened to unconditional help to thirdgenners. I am the one who refered him here....saying...if anyone knows....these guys will....he tried but i guess he didnt know how to set it up. anyways..i just posted for him. GM...that is the problem....he doesnt really know what is wrong....there is no power over 3000, horrible idle, and the timing was mysteriously set at 16*. he doesnt know much else....soooo...i came to you guys only to be scolded about singling out the guys who usually know whats wrong. Maybe i came to the wrong place....i thought you guys could help...i guess i was wrong.
Old Mar 10, 2001 | 07:20 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Chill out, man, we arn't scolding you, you just didn't give us much to work with. No power above 3K? Could be plugged cat, plugged fuel filter, bad fuel pump, etc... This list could go on.
As for the timing set at 16*, he must not be putting the timing in "bypass" mode. That is a brown/black wire over by the passenger strut tower area (its over there somewhere, don't remember exactly). It has a connector to it so its easily disconnected. Just unplug it and re-check your timing. It should NOT be 16+ degrees. Once you are done, hook the wire back up and clear the codes (CEL will be on w/ a code 42 set).
You may want to have him drive it w/ a fuel pressure gauge hooked up. I usually tape it to the windshield and make sure pressure is not dropping off when he is loosing power.
Does this help any?
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Old Mar 10, 2001 | 02:38 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
A friend of mine had a problem kinda similar. He had power up to about 3000rpms, but past that it felt like something was holding the car back almost. It also idled bad, not TOO bad, but it wasn't a nice smooth idle. He changed his fuel filter and it's great now. That only costs a few bucks, and only takes a short period of time to change, so it can't hurt.
Kevin
Old Mar 10, 2001 | 03:02 PM
Blade's Avatar
Hey Black Beauty, if you come to Vegas, shoot me up an email and I'll wouldnt mind meeting up with you, to show you other thirdgens here, where the street races are and maybe meet the rest of the truspeed crew here in Vegas.
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old Mar 10, 2001 | 10:51 PM
Car: 90 Camaro RS
Engine: 305 TBI
yes GM...it does help....i can understand saracasm .....too lazy to help....and frustration with lack of info...but that is all i have....i just needed SOMETHING....he has supposedly tried everything to fix it.....for 2 years!!! He said it finally got to the point where he is gonna sell it...so im tryin to help him out.
thanks Fire
Blade....will do....its a 3rdgen gathering in Vegas...sooo...there will be others....we'll be goin to the track that weekend too. i really wanna meet the tru memebers and Trav, and Anthony...if hes back in town by then. BTW...i saw an import up here with a TRUSPEED logo....different design but same spelling Should i slash his tires for ya???
GTAlover
Sep 19, 2001 09:03 PM
Timmys88Z
Aug 1, 2001 12:21 PM
