can my block use roller lifters
Old Mar 10, 2001 | 10:29 PM
Eric 91RS's Avatar
Car: 92 Chevy 1500
Engine: 350 TBI
Transmission: TH-700R4
I just purchased a 4 bolt main block. the casting # is 14093638 MorTec.com has it as 87-95 350 2 or 4 bolt mains with roller OR flat tappet cam. Mine is a 4 bolt but came with a flat tappet cam. I want to know if I can use a factory roller cam in this block. It has one piece rear seal.
91 RS LO3 305 Open Element, Chip, and Ultra Flow Muffler
55 Chevy on 76 4x4 frame 36" mudders (head turner)
Old Mar 10, 2001 | 10:45 PM
The ODB's Avatar
I don't see why not. Just get retrofit roller lifters.
Old Mar 10, 2001 | 10:51 PM
ede's Avatar
ede
if the block isn't made for the cam retainer under the cam gear and the spider for the lifters you can't use the factory roller, you'll have to go aftermarket
ICON Motorsports
1st & 3rd
Old Mar 10, 2001 | 10:52 PM
Eric 91RS's Avatar
Car: 92 Chevy 1500
Engine: 350 TBI
Thanks for the help.
Old Mar 10, 2001 | 11:26 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yep you can I have the same block in my garage it will soon be a 377.
cam retainer part# 1016-8501
lifterguides 8 req. #12550002
guide hold down#14101116
I got screwed the first time I ordered the cam retainer the guy ordered #1008-8128 which is too wide and the bolt hole wont line up. you may want to double check your block and see if it needs the wider one first but, I doubt it. also to save from fustration I had them look up the right torx screws for the retainer and got them from them.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
codeysabatini
Nov 10, 2015 04:07 PM
RyanJB
Sep 14, 2015 03:39 PM
dimented24x7
Sep 6, 2015 03:51 PM
