If i change cams, will I have to mess with the comp?
Old Apr 20, 2004 | 07:13 PM
ChevyCamaro420's Avatar
Car: '86 Z28
Engine: LB9 (305 TPI)
Transmission: 700R4 w/kit
The car is in sig... '86 Z28 w/LB9...
If I change from my horrible 179/194 camshaft that I have right now to a cam with 204/214 duration will I have to mess with the computer at all?
BTW - in '85 the cam's duration was 202/207, so this cam is just a little bit better than the stock '85's cam.
Any help would be appreciated.
Old Apr 20, 2004 | 07:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you get the version of that cam that's intended for FI, on 112 or 114 degree lobe separation, it should be OK. It'll cost a couple of extra coins though.
If you get the ultimate super-cheap ancient generic version of that cam with 110 degree LS that's been around since Peugeot started building cars, it won't work quite as well.
Old Apr 21, 2004 | 09:09 AM
Car: '86 Z28
lobe seperation is 112 degree's, so I should be cool right?
Old Apr 21, 2004 | 04:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Should be OK.
Old Apr 21, 2004 | 11:07 PM
Car: '86 Z28
alright thanks a lot man for the quick straight-forward answer
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
nuggie
Aug 25, 2015 01:27 PM
LT1Formula
Aug 20, 2015 09:36 PM
