cam swap tool
Old Apr 21, 2004 | 02:26 AM
dangerousd89's Avatar
Car: so many projects to little time
Engine: 350 tbi
cam swap tool
say guys i have recently seen a " cam swap tool" that eleminates the need to remove any of the top end of motor such as intake pushrods and so on. it a thin "sheetmetal cylinder that you grease and slide it in over the cam in the motor, slide the old cam out and slide the new cam in. remove metal sleeve.. has anyone heard of or used such a tool...
Old Apr 21, 2004 | 04:29 AM
ede's Avatar
ede
yeah it's about the same thing as a sky hook or a pipe strecher.
Old Apr 21, 2004 | 10:30 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
or you can use a really long bolt
Old Apr 21, 2004 | 11:06 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
he isn't talking about those camshaft handles.
and as for the topic, that would NEVER work.
the clearence is too tight between the cam and the cam bearings, and what if the lobes aren't the same height as the bearings.....
either way, it won't work. and with a flat tappet cam, you need to change your lifters anyway
Old Apr 21, 2004 | 11:13 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I dont think the lobes can be taller than the bearings. You wouldnt be able to get the cam past the rear-most lobe.
But gerenally, from all the engines i have seen, SBC and otherwise, the amount of clearance between the cam and bearings is very slim for a sleeving tool.
Old Apr 21, 2004 | 02:22 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
lol, that was about the most retarded thing i've said in awhile, thanks for catching that. I was still waking up this morning when i posted
Old Apr 22, 2004 | 02:29 AM
Engine: 350 tbi
really, tht weird because a guy at scoggin dickey swears up an ddown that it will work.. he even shewed it to me ..its a really thin sleeve thay slides over the cam.. he showed me instructions and all...so is this just a gimmick tool or is there some merit
Old Apr 22, 2004 | 04:21 AM
ede's Avatar
ede
post a link or a pic. there's something like .005 oil clearance between the cam and bearing so that would require the "cam tool" to be around .0015 wall. ever see a .0015 feeler gage?
Old Apr 22, 2004 | 10:16 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Agreed. .0015" feeler guage is... well... pretty damn thin.
Dkelz313
Apr 7, 2016 10:38 PM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
