can gears affect emissions?
Old Mar 11, 2001 | 02:03 AM
3.1 firebird's Avatar
I talked to someone about this and they told me that I need to correct my speedometer, so the computer"wont get confused" to my speed vs. RPM. Is this right?
Old Mar 11, 2001 | 11:10 AM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
I wouldn't know about the computer getting confused, but you would have increased emissions because with deeper gears the engine turns more rapidly at any given speed. More engine rotation @ same mph = more emissions per mile (due to more combustions per mile).
Old Mar 11, 2001 | 11:59 AM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
It will not affect emissions, I had my car inspected by the state of New Jersey (one of the strictest places). It was tested on a Dyno machine and it passed fine. I went from a 3.27:1 gear swap to a 3.73:1.
1988 GTA 5.7L TPI Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Ford Motorsports SVO 30 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, MSD Shift Light, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 4 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Flow Tech Pre-Cat 3" Exhaust Cut Off, ZR1 Heated O2 Sensor, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials 255/50 R16, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 11, 2001 | 02:40 PM
Bort62's Avatar
Think about it, No it will not effect emissions as Far as the Smog test is concerned.
What they do In cali here, is ttest you at Idle and at 2500 ( I think ) RPM.
Your gears have nothing to Do with this, last time I checked ) especially with the car In neutral.
Now in the Real World, Lower gears will increase the amount of Pollutants released per Mile you drive, but only because your burning more fuel, due to Poorer fuel economy becasue of the deeper gear.
Logic people, Logic!
No, Lowering your car will not effect emissions either.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
TBRays98
Sep 6, 2015 05:05 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
