fixing the charcoal canister
Old Apr 23, 2004 | 01:43 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
I want to put my charcoal canister back in, but I heard through the board that there was a way to move it out of the engine compartment, giving more room to work stuff around in. where do you put the canister when you relocate it? also, is it hard to do? does anybody have experience with this?
Old Apr 24, 2004 | 12:44 AM
Car: 1982 Trans Am
Engine: 383 chevy
anybody???
Old Apr 25, 2004 | 01:33 PM
Vader's Avatar
You can mount it under the vehicle, near the fuel tank, or inside a void in the inner fender. A flat EVAP works well for this, so you might be haunting the bone yards to find one you can fit up.
Old Apr 25, 2004 | 02:08 PM
Car: 1982 Trans Am
Engine: 383 chevy
flat EVAP? explain, if you don't mind. I've though about mounting it inside the void where the rear storage compartment is. there's a void underneath the compartment, I thought maybe it would fit. is that gonna leak a gassy smell in the car or anything? or would i be better off stashing it around the headlights or in the bumper??
Old Apr 25, 2004 | 09:15 PM
Vader's Avatar
Many later GM vehicles (like trucks, Malibus, Cavaliers, vans, etc.) have flat rectangular EVAP canisters mounted under the vehicle and nearer the fuel tank. One of these might fit well in a fender void or around the front side of the radiator shell. I would avoid mounting it anywhere inside the passenger compartment, like the rear cargo well.
Old Apr 26, 2004 | 12:11 PM
Car: 1982 Trans Am
Engine: 383 chevy
I think I'm just gonna stick with the big round one. how do I hook it up? is it just hook it to vac and let it run, or is there more to it? how do i route the vacuum? I looked at a diagram that was posted here, but I don't think it's for my car. any help would be great. thanks!!
Elephantismo
Feb 13, 2019 12:51 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
TBRays98
Sep 6, 2015 05:05 PM
